BookmarkSubscribeRSS Feed
fr2007
Jul 3, 2012
importing an excel sheet that contain alphanumeric column
Hello All,
May this one is the basic question for JMP, but I am little confused. Iam trying to import an excel sheet using File->open using JMP tool. My excel sheet has a column "Revision Level" that has values from 0 to 10 and also alphabets A to D. When Iam importing the excel file, only the numerical values from the "Revision Level" column are getting imported and I see blank spaces for the fields that contain the Alphabet values , A, B etc; How can I import the "Revision Level" column and see all the fields in JMP tool.
mpb
Jun 23, 2011
Solution
Re: importing an excel sheet that contain alphanumeric column
Try changing the format of the column in Excel to "Text" and then importing to JMP.
mpb
Jun 23, 2011
Solution
abel_shi
Feb 1, 2013
mpb is right!  You can have a try
