zakirosyidi
how we read the result?
hi, im the newbie for this analysis tools, so i cant read the result properly. i wanna ask you, how to explain the mosaic plot, contingency table, dendogram (and also the chart), and clustering history?
thanks alot
Re: how we read the result?
I suggest that you start off by bringing up the Help menus on each of the items you need to learn about, and read what JMP says about it.  Just click on the "Tools" pull down menu and select the ?Help tool.  Then move your cursor to the area you want to learn about, and click on it.  As an example, move to the Mosaic Plot, and click on it, and the Help screen for it will be displayed.
