robert_mcintyre
how to set alpha level for DOE in JSL
What is the syntax for setting alpha level in JSL for DOE?
Re: how to set alpha level for DOE in JSL
By example:
doe# = DOE(
Custom Design,
{Add Response( Maximize, "Y", ., ., . ),
Add Factor( Continuous, -1, 1, "X1", 0 ),
Add Factor( Continuous, -1, 1, "X2", 0 ),
Add Factor( Continuous, -1, 1, "X3", 0 ),
Add Factor( Continuous, -1, 1, "X4", 0 ),
Add Factor( Continuous, -1, 1, "X5", 0 ), Set Random Seed( 11149312 ),
Number of Starts( 1 ), Add Term( {1, 0} ), Add Term( {1, 1} ),
Add Term( {2, 1} ), Add Term( {3, 1} ), Add Term( {4, 1} ), Add Term( {5, 1} ),
Add Alias Term( {1, 1}, {2, 1} ), Add Alias Term( {1, 1}, {3, 1} ),
Add Alias Term( {1, 1}, {4, 1} ), Add Alias Term( {1, 1}, {5, 1} ),
Add Alias Term( {2, 1}, {3, 1} ), Add Alias Term( {2, 1}, {4, 1} ),
Add Alias Term( {2, 1}, {5, 1} ), Add Alias Term( {3, 1}, {4, 1} ),
Add Alias Term( {3, 1}, {5, 1} ), Add Alias Term( {4, 1}, {5, 1} ),
Set Sample Size( 12 ), Make Design}
doe report# = doe# << Report;
doe report#["Power Analysis"][NumberColEditBox(1)] << Set Values( [0.15] );
robert_mcintyre
Thanks Mark. I had hoped it was as simple as "Set Significance Level (.15)"
Got it.
If you follow Mark's example, the following works for me in 12.2:
doe# << set significance level(.15);
Cheers,
Ryan
