I wasn't sure about Score 1 and Score 2. I assumed that the two scores provides the range for your error bars. That means I stacked the Score columns first. For the Name column I turned on the Row Order Levels property so that JMP would plot them in the order they appear in the data table.
At the graph builder I drug the Name to the X-axis. I drug the Score column to the Y-axis. I changed the statistic to be the Mean with an Error Bar using the Range. I then drug the Gender column to the Overlay field and added the connector line. Results look like below. The JSL is below the graph.
![Graph Builder.png Graph Builder.png](https://community.jmp.com/t5/image/serverpage/image-id/14987iB90FCEDA7C28ADF9/image-size/large?v=v2&px=999)
Graph Builder(
Size( 528, 465 ),
Variables( X( :Name ), Y( :Score ), Overlay( :Gender ) ),
Elements(
Points(
X,
Y,
Legend( 5 ),
Summary Statistic( "Mean" ),
Error Bars( "Range" )
Line( X, Y, Legend( 6 ) )
Dispatch(
"400",
ScaleBox,
{Legend Model(
5,
Base( 0, 0, 0, Item ID( "F", 1 ) ),
Base( 1, 0, 0, Item ID( "M", 1 ) )
Dispatch( {}, "Graph Builder", FrameBox, {Marker Size( 6 )} )
Dan Obermiller
