Subscribe Bookmark RSS Feed
how to change column format several columns
KinKame
Nov 30, 2015
Hello
I have a table created thru summary feature.
I would like to using a for () loop (target column #3 to #9)
1) change format for fixed dec to Percent
2) add cell color
thank you
Lionel
Jun 22, 2012
Here is some sample code that I think will give you guidance on how to change the formats and the cell colors
dt = Current Data Table();
// Change the formats
For( i = 3, i <= 9, i++,
       Column( dt, i ) << Format( "Percent", 9, 2 )
// Set cell colors
For( rownum = 1, rownum <= N Rows( dt ), rownum++,
       If( Column( dt,3 )[RowNum] <= .5,
              Column( dt,3 ) << color cells( "Blue", RowNum ),
              Column( dt,3 ) << color cells( "Green", RowNum )
KinKame
Nov 30, 2015
Hello Jim
ok just using the column property (table, column number) ...
the set color is cool. JMP allows data manipulation in a nice way ...
thank ou very much.
very instructive post
KinKame
Nov 30, 2015
Jim,
I was trying to get a double For to address all row (as in your example) and multiple columns ...
but no success. Any idea?
For(ii=4, ii<11, ii++,
       Column(summary_executive_RNG_alignment, orignal_columns0[ii])
            << Format("Percent", 10, 1 );
            << justify text("center");
            For( RowNum = 1, RowNum <= N Rows( summary_executive_RNG_alignment ), RowNum++,
                 If( 0 < Column( summary_executive_RNG_alignment, orignal_columns0[ii])[RowNum] <= 0.6,
                      Column( summary_executive_RNG_alignment, orignal_columns0[ii] ) << color cells( "RED", RowNum ),
                      If(0.6 < Column( summary_executive_RNG_alignment, ii ) <= 0.9,
                           Column( summary_executive_RNG_alignment, orignal_columns0[ii]) << color cells( "Blue", RowNum ),
                           Column( summary_executive_RNG_alignment, orignal_columns0[ii]) << color cells( "GREEN", RowNum )
Jun 22, 2012
There are issues with your code.  The code below works, assuming the logic you are specifying is want you want.  The only statement that is not a valid statement is the << Justify Text("center").  It is only valid when referring to a display window text box.  The other errors are just improper references:
For( ii = 4, ii < 6, ii++,
       Column( summary_executive_RNG_alignment, orignal_columns0[ii] ) << Format( "Percent", 10, 1 );
       //<<justify text( "center" );
              If( 0 < Column( summary_executive_RNG_alignment, orignal_columns0[ii] )[RowNum] <= 0.6,
                     If( 0.6 < Column( summary_executive_RNG_alignment, ii )[RowNum] <= 0.9,
                           Column( summary_executive_RNG_alignment, orignal_columns0[ii] ) << color cells( "Blue", RowNum ),
                           Column( summary_executive_RNG_alignment, orignal_columns0[ii] ) << color cells( "GREEN", RowNum )
KinKame
Nov 30, 2015
Thank you for your fast feedback.
will study the code you proposed :-)
best regards
Lionel
