BookmarkSubscribeRSS Feed
paul_apicella
Feb 11, 2015
how to apply the same formula to several columns in a table?
I want to change the values contained in several columns of a database by applying a formula (see the attached example): values in "column a" must be modified according to  the formula (a - m1) / m2. Same procedure for "column b" ((b - m1) / m2) and similarly for each column.
Thanks in advance for any advice
ms
Jun 23, 2011
Re: how to apply the same formula to several columns in a table?
If you want to change the values in-place, i.e. overwrite the old values, the easiest way is to run a script.
dt = Data Table("test-table");
cols = dt << get column names;
For(q = 3, q <= N Items(cols), q++,
    For Each Row(cols[q][] = (cols[q][] - cols[1][]) / cols[2][])
paul_apicella
Feb 11, 2015
Thanks MS, it works very well !
