BookmarkSubscribe
xozhao0
Community Member
how to add a header in print out of the jmp graph. there is no option for this in the JMP 11.0 for Mac
I am using JMP 11.0 for Mac. I need to add a header to a histogram generated in JMP. However, in the page setup, I did not see the options for adding headers. how should I add a header?
Re: how to add a header in print out of the jmp graph. there is no option for this in the JMP 11.0 for Mac
JMP has built in headers for every analysis.  If you need to change the header double click in the header box for the distribution you are working with and then type in your desired header information.
