BookmarkSubscribe
alex
how do you use variables in a built in function?
I'm trying to use a variable in the below Distribution Procedure which is inside a function. It works if I hard code the text(the commented out 1), but when I put it in a variable(varB), it's not evaluating the variable.
Is there some thing fundamental I'm missing?
the Show(varB) tells me that the value has been correctly passed...
but then in the Distribution Procedure I get:
Name Unresolved: varB{1}
Thanks,
Alex
style='font-size:10.0pt;font-family:"Courier New";color:black'>RunTheVERTICAL
style='font-size:10.0pt;font-family:"Courier New";color:navy'>=
class=GramE>function
style='font-size:10.0pt;font-family:"Courier New";color:black'>(
style='font-size:10.0pt;font-family:"Courier New";color:black'>{
class=SpellE>varB
Show
style='font-size:10.0pt;font-family:"Courier New";color:black'> (
class=SpellE>varB
style='font-size:10.0pt;font-family:"Courier New";color:black'>Distribution(
style='mso-spacerun:yes'>
Continuous Distribution(
style='font-size:10.0pt;font-family:"Courier New";color:#0000DD'>Column
style='font-size:10.0pt;font-family:"Courier New";color:navy'>:
style='font-size:10.0pt;font-family:"Courier New";color:black'>E2E )
style='font-size:10.0pt;font-family:"Courier New";color:navy'>,
style='font-size:10.0pt;font-family:"Courier New";color:black'> Horizontal
Layout(
1 ), Vertical( 0 ) )
class=GramE>By(
:MonthFinish
style='font-size:10.0pt;font-family:"Courier New";color:black'> )
style='font-size:10.0pt;font-family:"Courier New";color:green'>//1// Where
class=GramE>( :
Group == "Name of Group1")
Where (
style='color:navy'>:
Group
style='font-size:10.0pt;font-family:"Courier New";color:navy'>==
class=SpellE>varB
style='font-size:10.0pt;font-family:"Courier New";color:black'>)
style='font-size:10.0pt;font-family:"Courier New";color:navy'><
style='font-size:10.0pt;font-family:"Courier New";color:black'> Set Window
Title (
"Histogram of E2E")
style='font-size:10.0pt;font-family:"Courier New";color:navy'>;
c
style='font-size:10.0pt;font-family:"Courier New";color:purple'>"Name of Group1"
style='font-size:10.0pt;font-family:"Courier New";color:#0000DD'>show
style='font-size:10.0pt;font-family:"Courier New";color:black'>c)
class=GramE>RunTheVERTICAL
("Name of Group1");
RunTheVERTICAL
style='font-size:10.0pt;line-height:115%;font-family:"Courier New";color:black'>(
style='font-size:10.0pt;line-height:115%;font-family:"Courier New";color:black'>c)
style='font-size:10.0pt;line-height:115%;font-family:"Courier New";color:navy'>;
6 REPLIES 6
pmroz
Re: how do you use variables in a built in function?
Take off the curly braces - that turns c into a list.
c = "Name of Group1";
If that still doesn't work try
RunTheVERTICAL(eval(c));
alex
neither of those works....
if you look at the 2nd line, the show(varB) works correctly....I get this output in the log...
varB:"Name of Group1"
varC:"Name of Group1"
Check for updates. I get the same error in JMP 8.0 but the script runs fine in JMP 9. Sorry I don't know what the fix was.
pmroz
Try this:
Where ( :Group == eval(varB) )
If that doesn't work you may need to use something like this:
RunTheVERTICAL = function({varB},
Show (varB);
eval(
eval expr(
Distribution(
Continuous Distribution( Column( :E2E ), Horizontal Layout( 1 ), Vertical( 0 ) ),
By( :MonthFinish ),
Where ( :Group == expr(varB) )
)<< Set Window Title ("Histogram of E2E");
alex
@spokedude, i'm stuck on 8 for a while longer... if its a v8 bug then i'm happy to know that.
@PMroz
the 1st solution didn't work but the 2nd one did! awesome and thanks so much.
i have to admit i read through the expr/eval sections of the JMP Scripting Guide earlier today and couldn't make sense of them......i'm still not really sure. Re the above, do you think its a bug?
Really happy it works now. Thanks Again.
Regards,
Alex
pmroz
No it's not a bug. I find eval, eval expr, expr, parse, etc. confusing as well. I've picked up a few techniques here and there to work around JSL's "features", especially wrt functions. Apply the techniques and move on ;).
