BookmarkSubscribeRSS Feed
how do i select columns when I open a JMP file.
when I open a jmp file, there is an option at the window bottom to select columns. how to do it by script?
Re: how do i select columns when I open a JMP file.
If you just want to select a specified column or columns, you can do it either by column number or name as shown in the first few lines below. If you want to do it interactively, use the Column Dialog command: I've included below an example of how you could use it to select a third column in addition to the first two:
style="font-size: 9pt; font-family: "Courier New"; color: black;">
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Clear
Log
style="font-size: 9pt; font-family: "Courier New"; color: black;">()
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="font-size: 9pt; font-family: "Courier New"; color: black;">dt
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Open
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"$SAMPLE_DATA/Big
Class.jmp"
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Column
dt
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,
style="font-size: 9pt; font-family: "Courier New"; color: teal;">2
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><<
set selected
dt
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"weight"
set selected
style="font-size: 9pt; font-family: "Courier New"; color: black;">VarList
Dialog
style="">
title(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Select
3rd Column"
style="">
ThirdCol
ColList(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Choose"
Min Col(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">1
Max Col(
style="font-size: 9pt; font-family: "Courier New"; color: black;">)
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Show
VarList )
style="font-size: 9pt; font-family: "Courier New"; color: green;">/*
If the final item in the list
is the 'OK' button then assign the 3rd column */
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">If
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Char
VarList[
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">N
Items
VarList )]
style="font-size: 9pt; font-family: "Courier New"; color: navy;">==
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Button(1)"
style="">
dt
VarList[
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"ThirdCol"
style="font-size: 9pt; font-family: "Courier New"; color: black;">][
set selected
style="">
style="">
Does that cover it? Incidentally, I'd be interested to know if there's a less messy way to check to see if the 'OK' button was pressed when leaving Column Dialog than the way I've done it above.
David
Here is the standard pattern that I use for dealing with dialog buttons:
dlg = Dialog( ..... );
If ( dlg["Button"]==-1,
Throw()
thanks for your reply David. However, my question is to get the columns without open the original table which is very large..
mpb
Jun 23, 2011
I don't know of any direct way to open only selected columns via scripting (though it may be possible) but it may be of interest to note that if your file is stored as an Excel file or an Access database or any other kind of file that has an ODBC driver installed, then you could use the Open Database command with SQL to select and load only the desired columns.
I feel completely sure that there's no way to get a column listing without first opening the data table.
And David: I think you've got the best way of detecting the OK button. There's no specific routine to do this. It all comes down to the fact that the dialog returns a list, aht you've got to use generic list processing thingees to examine it.
