BookmarkSubscribeRSS Feed
jmp_ingbean
Oct 23, 2013
how do I create a bar chart with a regression line?
we want to use an numeric/ordinal column and a numeric/continuous column to populate a vertical bar chart, with the former on the x axis and latter on the y axis
this is amazingly easy in jmp, done in 20 seconds
now we want to fit a regression line to the tops of the bars, ie the data
this is amazingly hard in jmp, cant figure it out -- has to do with the ordinal data on the x axis, but... does this mean it's impossible?
help? thanks
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: how do I create a bar chart with a regression line?
You're right that having a categorical (ordinal) column on the axis is the problem. JMP doesn't want to fit a regression line to categorical data.
However, if you change the modeling type to of your X axis variable to Continuous, you can still plot the bar chart and get the regression line.
In the picture below I've changed the modeling type of the Age column in Big Class from Ordinal to Continuous and then created the graph you're looking for.
-Jeff
