how do I change the number of legend from the graph builder plot?
This is what it;s shown despite increasing the legend from the script file
Graph Builder(
  Size( 534, 545 ),
  Show Control Panel( 0 ),
  Variables(
  X( :Coord_X ),
  Y( :Coord_Y ),
  Overlay( :Name( "C2_10V (pF) - C0_0V (pF)" ) )
  Elements( Points( X, Y, Legend( 15 ) ) ),
  Dispatch(
  "400",
  ScaleBox,
  {Legend Model(
  15,
  Level Name( 0, "-0.1 - 0" ),
  Level Name( 1, "0.045 - 0.055" ),
  Level Name( 2, "0.055 - 0.065" ),
  Level Name( 3, "0.065 - 0.075" ),
  Level Name( 4, "0.075 - 0.085" ),
  Level Name( 5, "0.085 - 0.095" ),
  Level Name( 6, "0.095 - 2.1945" ),
  Properties( 1, {Line Color( -127 ), Fill Color( -127 )} )
Re: how do I change the number of legend from the graph builder plot?
The legend is going to only show the data it finds in the data table.  However, if you run the graph against the entire data table, with all of the levels you want in the legend, you can then apply a Global Data Filter, select the checkboxes for "Select" and "Show", but do not select the "Include" checkbox, and then go to the choices for
and select only the levels you want show in the graph, and you will get the graph you want.
Below is an example:
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
dt << Graph Builder(
                Size( 534, 453 ),
                Variables( X( :PNP1 ), Y( :NPN1 ), Overlay( :lot_id ) ),
                Elements( Points( X, Y, Legend( 12 ) ) ),
                             Dispatch(
                                     "400",
                                ScaleBox,
                                {Legend Model(
                                             12,
                                           Base( 0, 0, 0 ),
                                           Base( 1, 0, 0 ),
                                           Base( 2, 0, 0 ),
                                           Base( 3, 0, 0 ),
                                           Base( 4, 0, 0 ),
                                           Base( 5, 0, 0 ),
                                           Base( 6, 0, 0 ),
                                           Base( 7, 0, 0 ),
                                           Base( 8, 0, 0 ),
                                            Base( 9, 0, 0 ),
                                            Base( 10, 0, 0 ),
                                            Base( 11, 0, 0 ),
                                            Base( 12, 0, 0 )
dt << Data Filter(invisible,
      Location( {30, 30} ),
       Mode( Show( 1 ) ),
      Add Filter( columns( :lot_id ), Where( :lot_id == {"lot1", "lot11"} ), Display( :lot_id, Size( 204, 225 ), List Display ) )
