BookmarkSubscribeRSS Feed
swu2
Community Trekker
Jan 27, 2017
how do I change column 1 name from all open data table
openDTs = List();
For( i = 1, i <= N Table(), i++,
Hello All,
I want to change the column name from all open data table, but my script only changed the last data table, would you please help?
openDTs = List();
Insert Into( openDTs, Data Table( i ) ));
For( i = 1, i <= N Items(openDTs), i++,
column(1)<<openDTs[i]<<set name("DATE");
show(openDTs[i]));
Justin_Chilton
Aug 27, 2015
Solution
Re: how do I change column 1 name from all open data table
The way your code is written now does not work because Column(1) references the first column in the current data table and therefore will only change the column name of a single table. It seems like your placement of openDTs[i] is a little off. Below is how you would address this.
openDTs = List();
For( i = 1, i <= N Items( openDTs ), i++,
	Column( openDTs[i], 1 ) << set name( "DATE" )
However, a better way to do this is to only use a single loop and set the name of the column use the Data Table function with a table index. This avoids looping to create a list and then looping that list to set the names.
	Column( Data Table( i ), 1 ) << set name( "DATE" )
Justin
Justin_Chilton
Aug 27, 2015
Solution
openDTs = List();
Justin
swu2
Community Trekker
Jan 27, 2017
Thank you very much, it works
Jun 22, 2012
this should work
openDTs = List();
	Column( openDTs[i], 1 ) << set name( "DATE" );
	Show( xx );
