galactus3000
how do I access likelihood distributions for Life Distributions?
I would like to gain access to likelihood distributions for reliability life distributions, for example defective subpopulation weibull.  specifically I would like to run a monte carlo on a function of the distribution parameters alpha, beta and p.  Thanks in advance.
cwillden
Re: how do I access likelihood distributions for Life Distributions?
If so, here's a script that will show you an example of how to extract those values:
//Create Data Table with random lognormal data
dt = New Table("Example Data");
dt << New Column("X",formula(random log normal()));
dt << Add Rows(300);
//Expression to fit Life Distribution with Log Normal fit & get parameter estimates
fit_and_get = Expr(
	LD = dt << Life Distribution(
		Y( :X ),
		<<Fit Lognormal,
		Confidence Interval Method( Wald ),
		<<Set Scale( Lognormal ),
		<<Suppress Plot( Nonparametric ),
		Interval Type( Simultaneous ),
		Show Event Plot Frequency Label( 0 ),
		<<Set Scriptables(
			{Probability Paper(
				Profiler(
					1,
					Confidence Intervals( 1 ),
					Term Value( X( 6.97984876476196, Lock( 0 ), Show( 1 ) ) )
			), Lognormal Distribution(
				Profiler(
					1,
					Term Value( X( 6.98, Lock( 0 ), Show( 1 ) ) )
			), Lognormal Quantile(
				Profiler(
					1,
					Term Value( Probability( 0.5, Lock( 0 ), Show( 1 ) ) )
			), Lognormal Hazard(
				Profiler(
					1,
			), Lognormal Density(
				Profiler(
					1,
					Confidence Intervals( 0 ),
			), Custom Estimation( Lognormal, 0 )}
			Dispatch(
				{"Compare Distributions"},
				"Life Distribution",
				FrameBox,
				{Grid Line Order( 2 ), Reference Line Order( 3 )}
			Dispatch(
				"Distribution Profiler",
				OutlineBox,
				{Set Summary Behavior( "Collapse" )}
			Dispatch(
				{"Statistics"},
				ListBox,
		Invisible
	rprt_win = LD << Report; //get reference to window containing Life Distribution report
	params = rprt_win["Parametric Estimate - Lognormal"][TableBox(1)][Number Col Box(1)] << Get as Matrix; //navigate to number col box with parameter estimates & get the values
	likelihood = (rprt_win["Parametric Estimate - Lognormal"][TableBox(2)][Number Col Box(1)] << Get as Matrix)[1]; //get -2*likelihood
	rprt_win << Close Window;
//Sim 5 data sets and output values
for(i = 1, i<=5, i++,
	dt:X << Eval Formula;
	fit_and_get();
	Show(params, likelihood);
If you run it and look at the log, you'll see 5 different sets of parameter estimates and loglikelihood values
-- Cameron Willden
If you want to access the distribution functions for the purpose of a simulation, see Help > Scripting Index > Functions > Probability. The PDF, CDF, and ICDF are available for the common reliability life distribution models.
