z2632941
how could I give a defined name to the script?
Hi, everyone
    I have too many variables need to run the same script(generate a graph), and also need save the script of each variable , the question is that  for each variable how to name its script instead of JMp specified name ?(profiler 2 、profiler 3)
Re: how could I give a defined name to the script?
once you do the
   << save script to data table
you can change the script name to whatever you want using
dt << Rename Table Script(
  "Current Script Name",
  "New Script Name"
