guy_yosef
how can i remove the "where(:... " from journal chart
i made a script that collect data from several tables and create charts with limits for each paramter
the script collect the limits from one table and data from anotehr
when i create bivariate chart only it works fine
when i create one way box plot chart it wroks fine
but when i try to combine them using H List Box i get this Where(:   line
how can i remove it?
uday_guntupalli
Level VIII
Re: how can i remove the "where(:... " from journal chart
@guy.yosef
          Can you please use a sample data set from the JMP library and reproduce the issue here . It would be hard for any one who is trying to help you to keep trying to edit your code. Rather - if you can zero in on the exact piece of code that is causing you trouble and you do this by using the sample data - everyone will be able to reproduce the issue on their end and help you fix the problem
Best
Uday
Best
Uday
vince_faller
Lets assume you are getting it in something called nw and you only have textboxes that are where textboxes;
I just use:
obt = nw<<xpath("//TextBox");
for(i=1, i<=nitems(obt), i++,
obt << Delete
there are a lot of customization you can do with it but this normally works for me.
Vince Faller - Predictum
Article Labels
