mwilli13
how can i have this design script automatically saved as a .csv? also, when the design is created it adds two columns X1 and X2, how can i make that not be a part of the script? Thank you!
DOE(
Space Filling Design,
{Add Response( None, "Tacc", ., ., . ),
Add Factor( Categorical, {"8", "16"}, "cmux", 0 ),
Add Factor(
  Categorical,
  {"8", "16", "32", "64", "128", "256", "512"},
  "rows",
  0
), Add Factor(
  Categorical,
  {"32", "64", "96", "128", "160", "192", "224", "256", "288", "320", "352",
  "384", "416", "448", "480", "512", "544", "576", "608", "640"},
  "cols",
  0
), Add Factor( Continuous, 0.01, 1, "slew", 0 ),
Add Factor( Continuous, 0, 0.5, "load", 0 ),
Add Factor( Continuous, -40, 125, "temp", 0 ),
Add Factor( Continuous, 0.81, 0.99, "volt", 0 ), Set Random Seed( 958977147 ),
Disallowed Combinations( cmux == 2 & cols == 1 ),
FFF Optimality Criterion( MaxPro ),
Space Filling Design Type( Fast Flexible Filling, 100 ), Make Table}
Re: how can i have this design script automatically saved as a .csv? also, when the design is created it adds two columns X1 and X2, how can i make that not be a part of the script? Thank you!
I am not sure this is what you are asking for. I read your question several times, and came up with a couple of different things you might be asking for.  However, what I believe you want is to automatically take the data table(fast filled design) created and to save it to a .csv file.  Additionally, do not save the X1 and X2 columns.  The script below does that.  If I have misinterpreted your request, could you please re-ask it so I can get a better idea of what you want.
TheDOE=DOE(
       {Add Response( None, "Tacc", ., ., . ), Add Factor( Categorical, {"8", "16"}, "cmux", 0 ),
       Add Factor( Categorical, {"8", "16", "32", "64", "128", "256", "512"}, "rows", 0 ),
       Add Factor(
              Categorical,
              {"32", "64", "96", "128", "160", "192", "224", "256", "288", "320", "352", "384", "416", "448", "480",
              "cols",
              0
       ), Add Factor( Continuous, 0.01, 1, "slew", 0 ), Add Factor( Continuous, 0, 0.5, "load", 0 ),
       Add Factor( Continuous, -40, 125, "temp", 0 ), Add Factor( Continuous, 0.81, 0.99, "volt", 0 ),
       Set Random Seed( 958977147 ), Disallowed Combinations( cmux == 2 & cols == 1 ),
       FFF Optimality Criterion( MaxPro ), Space Filling Design Type( Fast Flexible Filling, 100 )}
dt=TheDOE<<make table;
dt<<delete columns("x1","x2");
dt<<save as("C:\Users\txjim\Documents\JMP\design.csv");
TheDOE=DOE(
       Add Factor(
              Categorical,
              "cols",
              0
mwilli13
Yes that was it! Thank you very much!
