Attached is sample of data in first 3 cells of the column "information" .
I need keep "first name" and "start date" if present and delete remaining txt in that cell of the column.
cell 1 = Unknown Pic, CV, start date, stop date, first name, last name
cell 2 = start date, stop date, Unknown Pic, first name, risk data
cell 3 = Unknown Pic, risk data, sart date
I have tried munger, left and right commands to remove un wanted text. will it be possible to use "Remove" command to remove specific text such as " Unknown Pic"
Any guidance will be Helpful
Thanks
Gow
Linlin I think by attached Gow meant "shown below". Anyway this code might help:
// I need to keep "first name" and "start date" if present and delete remaining txt in that cell of the column.
cell = {};
cell[1] = "Unknown Pic, CV, start date, stop date, first name, last name";
cell[2] = "start date, stop date, Unknown Pic, first name, risk data";
cell[3] = "Unknown Pic, risk data, start date";
for (i = 1, i <= nitems(cell), i++,
new_cell = "";
if (contains(cell[i], "first name"),
new_cell = "first name";
if (contains(cell[i], "start date"),
if (new_cell == "",
new_cell = "start date";
new_cell = new_cell || ", " || "start date";
cell[i] = new_cell;
write(cell);
Gow: if "first name" and "start date" are meant to be variables then you might try using the WORDS function to parse each string.
Thanks, this helped me to figure out the issue.
