bluebird
histogram axis won't copy
I'm using the Distribution function to produce histograms and it works great, mostly. When I change the count axis setting on one particular histogram, it won't copy as it appears in the dialog box to GIMP or any other image program. The trouble seems to only occur when I make a large change in the axis scale. In this case from a maximum of 8 (as in the original histogram generated) to 60 and increments of 5 (the scale I need). The copied histogram has the correct axis but the histogram bars revert back to the original scale. Any suggestions?
