saitcopuroglu
hiding a step in a final output (invisible command, private command)
Hi all,
Before making a graph I needed to make some "categorical" work and "save transposed frequencies"
     objsemantic = Categorical(
            Count Missing Responses( 0 ),
            Order Response Levels High to Low( 1 ),
            Multiple Delimited( :SEMANTICS POS ),
            Multiple Delimited( :SEMANTICS NEG ),
            Share Of Responses( 0 ),
            Rate Per Case( 0 ),
            Share Chart( 0 ),
            Legend( 0 ),
            Total Cases( 0 ),
            Total Cases Responding( 0 ),
            Mean Score( 1 ),
            Contents Summary( 0 ),
            Force Crosstab Shading( 0 )
        objsemantic << Save Transposed Frequencies;
And then the graph comes but the final output also displays the categorical steps which I would not like.
I know there are "invisible" and/or "private" commands for these cases but wherever I placed it, it did not work.
Many thanks for help
brent_ginn
Re: hiding a step in a final output (invisible command, private command)
I don't recall the exact JSL but I am pretty sure you can delete those outline boxes from the report window to get the look you want.
saitcopuroglu
final html5 output after deleting the categorical outline box:
final html5 output after deleting 3 related outline box:
ms
Super User ms
To continue on Brent's idea; the JSL for deleting the Categorical outline box could be something like this
Current Report()[Outline Box("Categorical")] << delete;
