skyzvoir0001
help with code
para = {"Age","Orientation","Preference","Salary","Number","SN","Years","Service"} //some of the column names needed
main_table_col_remain = main_tab << get column names(string);
For( i = N Items( main_table_col_remain ), i > 0, i--,
	If(!Contains( main_table_col_remain[i], ?? ) ,
		Remove From( main_table_col_remain, i )
What do i put in the "??" part? I've been circling around this code for a while now. I want to remove column names not stored in para.
Re: help with code
You had the comparison backwards.  You want to take the main_table_col_remain[1] and look into the para list to see if it is there then remove it from the main_table_co_remaining list
para = {"Age", "Orientation", "Preference", "Salary", "Number", "SN", "Years", "Service"}; //some of the column names needed
main_table_col_remain = main_tab << get column names( string );
	If( Contains( Para, main_table_col_remain[i] ),
		Remove From( main_table_col_remain, i, 1 )
Re: help with code
skyzvoir0001
Re: help with code
follow up question, how do i tweak this code so that it does not split it individually?
for(i=1, i<=n, i++,
	if((contains item(Para[i], main_table_col_remain) == 1),
		param = main_table_col_remain[i];
		tempdt =eval(parse( " combined_tab << Split(
		Split By(:Source_Table),
		Split(:Name(\!"" ||param|| "\!")),
		Remaining Columns(Drop All),
		Sort by Column Property
Re: help with code
If I am correctly reading what you want to do, all you need to do, is to place all of the main_table_col_remain columns into the Split definition at the same time.  Here is a simple example of splitting both Height and Weight by the Sex column in the Big Class sample data table
dt << Split( Split By( :sex ), Split( :height, :weight ), Remaining Columns( Drop All ), Sort by Column Property );
With the complex names you have in your data table, I would have a tendency to add :Name() to each element in your main_table_col_remain and in your case, turn the list into a string
myString = ":Name( \!"" || char(main_table_col_remain[1]) || "\!" )";
For( I = 2, I<= N Items( main_table_col_remain ), i++,
     myString = myString || ", :Name( \!"" || char(main_table_col_remain[i]) || "\!" )" ;
then you can add the entire list to the split
main_table_col_remain = dt << get column names( string, continuous );
myString = ":Name( \!"" || Char( main_table_col_remain[1] ) || "\!" )";
For( I = 2, I <= N Items( main_table_col_remain ), i++,
	myString = myString || ", :Name( \!"" || Char( main_table_col_remain[i] ) || "\!" )"
Eval(
	Parse(
dtSplit = dt << Split(
	Split By( :sex ),
	Split( " || myString ||
