gianpaolo
help with R and mongo_db connection
hello community
i'm trying to connect on MongoDb through R interface by JSL script
i need to pass this strings
RConnection = R Connect();
rc = RConnection << Submit("
library(mongolite)
m <- mongo(collection = "Param", db = "DbParam", url = "mongodb://ailyxxxx01a:27017/DbParam")
d <- m$find('{"\"FLDLOT" : "\""xxxxxx.000\""}')
but i got sintax errors
how i can pass red strings correcty into code?
thanks in advance
Gianpaolo
Gianpaolo Polsinelli
gianpaolo
Re: help with R and mongo_db connection
I solved it by myself:
the issue was related to sintax error introduced by "  into R code
need to use escape characters because  to substitute  " with  \!"
R Init( );
R Submit(
library(mongolite)
m <- mongo(collection = \!"ColParamLot\!", db = \!"DbaLfoundryParam\!", url = \!"mongodb://ailymsmdb01a:27017/DbaLfoundryParam\!")
d <- m$find('{\!"FLDLOT\!" : \!"8588679.009\!"}')
R Term();
uday_guntupalli
Level VIII
@gianpaolo
              Were you able to successfully connect to MongoDB using R outside JMP ? I would suggest you to share your syntax errors as well to provide the community a better insight into what your problems might be
Best
Uday
gianpaolo
in red below the error
Unexpected "ColParamLot". Perhaps there is a missing "," or ")".
Trying to parse arguments of function "Submit".
Line 12 Column 27: m <- mongo(collection = \"►"ColParamLot""\, db = \"
uday_guntupalli
Level VIII
@gianpaolo
   Were you able to connect to mongodb using just R outside JMP ?
   Additionally, look at this. I don't have mongodb so - cannot replicate the error .
https://datascienceplus.com/using-mongodb-with-r/
Best
Uday
gianpaolo
the code work well.... i did it with R and i obtain the data
library(mongolite)
so.. is the JSL script that has sintax error.... i suppose becasue this " "  characters
gianpaolo
R Init( );
R Submit(
library(mongolite)
R Term();
