qt
qt
group and plot using scripts
Hi, JMP experts,
I have a table like this:
School Var1 Var2 Var3 ..... VarN
Sch_A  .....
Sch_B .....
Sch_C ....
I tried to make X-Y Scatter plot and then group them by "School", then add fit lines using JMP scripts.
Here is the code I copied:
Bivariate(
    Y( :Var2 ),
    X( :Var1 ),
   Fit Where(
        :School == "Sch_A",
        Fit Spline( 2, Standardized, {Line Color( {42, 63, 255} )} )
    Fit Where(
        :School == "Sch_B",
        Fit Spline( 2, Standardized, {Line Color( {23, 138, 138} )} )
    Fit Where(
        :School == "Sch_C",
        Fit Spline( 2, Standardized, {Line Color( {121, 123, 5} )} )
    Fit Where(
        :School == "Sch_D",
        Fit Spline( 2, Standardized, {Line Color( {252, 11, 11} )} )
        Dispatch(
            "Bivar Plot",
            FrameBox,
            {Row Legend(
                School,
                Color( 1 ),
                Color Theme( "JMP Default" ),
                Marker( 0 ),
                Marker Theme( "" ),
                Continuous Scale( 0 ),
                Reverse Scale( 0 ),
                Excluded Rows( 0 )
Is it possible to make the blue part more general? Can I use GroupBy, and Color Theme, so I don't need to add the name/color for each group one by one.
Thanks!
Qian
ms
Super User ms
Re: group and plot using scripts
Yes, use Group By(:School) as in the example below. Colors will be set automatically.
biv=dt << Bivariate(
  Y( :height ),
  X( :weight ),
  group by( :sex ),
  Fit Spline( 2, Standardized ),
report(biv)[Framebox(1)]<<row legend(sex)
