BookmarkSubscribeRSS Feed
tonyuow
Dec 20, 2011
graph with not all the rows
is it possible to creat a graph (whether in "graph builder" or "fit y by x") with only a selected number of rows, instead of the entire range of rows?
thanks
David_Burnham
Jul 13, 2011
You can select the rows that you do not wish to show and then use the Hide property on the rows menu.  Alternatively use the Data Filter.
Dave
-Dave
tonyuow
Dec 20, 2011
the problem is that, if I unhide these rows because I need them for another graph, they will re-appear on the 1st one.
ms
Jun 23, 2011
Use duplicate tables, or make subsets with the rows you need for each set of graphs.
