BookmarkSubscribeSubscribe to RSS Feed
goodness of fit - include in a script
mainak29
Occasional Contributor
Nov 13, 2017
Dear all,
I'm triyng to add a goodness of fit after a distribution, using a script. There is a loop. The analysis is performed for n columns.
this is the part of the code:
	disti = dt << Distribution(
		stack( 0 ),
		Continuous Distribution(
		Column( listName[i] )),
		Normal Quantile Plot( 1 ),
		Fit Distribution( Normal(Goodness of Fit( 1 ) )),
		Capability Analysis( 1 ),
		Invisible( 1 )
But no goodness of fit appears... and  I don't konw why..
Do you have an idea?
 What does it mean the "1" parameter of this function?
Thank you
Maïna
Jun 22, 2012
Solution
I have expanded your script slightly, to make it a functioning script.  Your code works well using the Semiconductor Capability data table.  I suggest that you look at the makeup of your data or the list, "listName".
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
listName = dt << get column names( numeric, continuous );
For( i = 1, i <= 2, i++,
		stack( 0 ),
		Continuous Distribution( Column( listName[i] ) ),
		Fit Distribution( Normal( Goodness of Fit( 1 ) ) ),
		Invisible( 1 )
Jun 22, 2012
Solution
		stack( 0 ),
		Invisible( 1 )
mainak29
Nov 13, 2017
Thank you Jim,
I have already do this loop :) IThe script is bigger !
My first script was like that:
The distribution appears, the capability analysis too, but not the goodness of fit test...
I don't understand why ;(
		stack( 0 ),
		Invisible( 1 )
 But I want to add a goodness of fit analysis below the histogram of the distribution.
Tks
David_Burnham
Jul 13, 2011
Do you have the same problem if you run Jim's script?
-Dave
mainak29
Nov 13, 2017
No, It works well !
Jun 22, 2012
I used your script, and just attached a different data table, so that is why I suggested that you need to look elsewhere.
mainak29
Nov 13, 2017
Or do I have no place to display the result?
Would that be possible?
Jun 22, 2012
Are the columns you are analyzing of Modeling Type Continuous?  If they are Ordinal or Nominal, they will not provide a goodness of fit
mainak29
Nov 13, 2017
yes, all my columns are in continuous type
