BookmarkSubscribeRSS Feed
matteo_patelmo
Dec 23, 2015
get column properties() -> changed behavior?
Hello, I've upgraded recently to JMP Pro 13.2 from release 12.2.
The following simple script applied on a data table with just an empty column1 with some properties set creates a second column and copies the properties from column1 to column2.
dt= current data table();
dt<<add rows(1);
c=column(1);
p=c<<get column properties();
c2=new column("column 2");
c2<<add column properties(p);
It used to work on 12.2, but it does not work on 13.2.  Variable p cointains the same expression, but "add column properties" will not add any property to column2 in version 13.2.
Did anyone out there notice this changed behavior? Which version introduced this change (13.0, 13.1, 13.2)?
thanks in advance
Matteo
Jun 22, 2012
Solution
Re: get column properties() -> changed behavior?
I have validated your findings between 12.2 and 13.2.1.  You need to get this to
     support@jmp.com
matteo_patelmo
Dec 23, 2015
Solution
Hi Marvin, yes they suggested using eval(eval expr(... expr(p))) as
workaround.
bye
matteo
Jun 22, 2012
Solution
     support@jmp.com
matteo_patelmo
Dec 23, 2015
thanks Jim. I will certainly do so.
Matteo
mkennke
Mar 18, 2016
did you got an answer? I have the same Problem.
Regards,
Marvin
matteo_patelmo
Dec 23, 2015
Solution
workaround.
bye
matteo
