I need to generate multiple fit y by x graphs. the number of graphs generated will vary based on the unique values in the 'RECIPE' column (used in the where clause)
example:
Oneway(
Y( :VALUE ),
X( :TOOL ),
Box Plots( 1 ),
X Axis Proportional( 0 ),
Grand Mean( 0 ),
Where( :RECIPE == "RecipeA" )
SendToReport(generate
etc
etc
etc
RECIPE column could contain any number of unique values ("RecipeA", "RecipeB", "Recipe67283", etc...), thus generating any number of different y by x graphs for each unique RECIPE.
when I copy the jump script, it just generates an additional block of code for each unique Where( :RECIPE == "__________") value.
I need this script to apply to any dataset, so i cannot specifically call out a string to match in the Where clause since these strings will vary based on the dataset!
I tried using a wildcard (?) in the Where string and that didn't work:
example
Oneway(
Y( :VALUE ),
X( :TOOL ),
Box Plots( 1 ),
Grand Mean( 0 ),
Where( :RECIPE == "?" )
etc
etc
I'm guessing the best way to accomplish this is to utilize Associative Arrays?
If i use this code to create an array of unique RECIPES:
uniqueRecipes = associative array(:RECIPE);
and then try to grab a specific key value, say the first one:
Oneway(
Y( :VALUE ),
X( :TOOL ),
Box Plots( 1 ),
Grand Mean( 0 ),
Where( :RECIPE == uniqueRecipes <<First )
etc
etc
the above did not work..
but if i run just this line of code:
I get the correct string returned:
"RecipeA"
I am completely stumped.. maybe using associative arrays is just the wrong approach to begin with and there is an easier way? My thought was that if i could use array values in the Where clause, then i could use some sort of loop to iterate through each of the unique values in the array...
any help is GREATLY appreciated! thank you for your time
Oneway (
Y( :VALUE ),
X( :TOOL ),
By( :RECIPE )
Oneway (
Y( :VALUE ),
X( :TOOL ),
By( :RECIPE )
Wow that worked! so simple, yet I was making it so complex... when i copied the script that JMP wrote by way of selecting from UI, it had used the Where( ) command and not the By( )
thank you! you just saved me hours of frustration!
When you interactively use a platform and specify a By variable, then instead of using Script to save the script, use Script All By-Groups from the same red triangle pull down menu. Then you'll see By instead of multiple Where blocks.
