jmpbeginner
generate N 'fit y by x' charts for N unique values in column (where == unique values from column)
I need to generate multiple fit y by x graphs. the number of graphs generated will vary based on the unique values in the 'RECIPE' column (used in the where clause)
example:
Oneway(
  Y( :VALUE ),
  X( :TOOL ),
  Box Plots( 1 ),
  X Axis Proportional( 0 ),
  Grand Mean( 0 ),
Where( :RECIPE == "RecipeA" )
SendToReport(generate
etc
etc
etc
RECIPE column could contain any number of unique values ("RecipeA", "RecipeB", "Recipe67283", etc...), thus generating any number of different y by x graphs for each unique RECIPE.
when I copy the jump script, it just generates an additional block of code for each unique Where( :RECIPE == "__________") value.
I need this script to apply to any dataset, so i cannot specifically call out a string to match in the Where clause since these strings will vary based on the dataset!
I tried using a wildcard (?) in the Where string and that didn't work:
example
Oneway(
  Y( :VALUE ),
  X( :TOOL ),
  Box Plots( 1 ),
  Grand Mean( 0 ),
  Where( :RECIPE == "?" )
etc
etc
I'm guessing the best way to accomplish this is to utilize Associative Arrays?
If i use this code to create an array of unique RECIPES:
uniqueRecipes = associative array(:RECIPE);
and then try to grab a specific key value, say the first one:
Oneway(
  Y( :VALUE ),
  X( :TOOL ),
  Box Plots( 1 ),
  Grand Mean( 0 ),
  Where( :RECIPE == uniqueRecipes <<First )
etc
etc
the above did not work..
but if i run just this line of code:
I get the correct string returned:
"RecipeA"
I am completely stumped.. maybe using associative arrays is just the wrong approach to begin with and there is an easier way?  My thought was that if i could use array values in the Where clause, then i could use some sort of loop to iterate through each of the unique values in the array...
any help is GREATLY appreciated!  thank you for your time
mpb
Super User mpb
Re: generate N 'fit y by x' charts for N unique values in column (where == unique values from column)
Oneway (
    Y( :VALUE ),
    X( :TOOL ),
    By( :RECIPE )
mpb
Super User mpb
Oneway (
    Y( :VALUE ),
    X( :TOOL ),
    By( :RECIPE )
jmpbeginner
Wow that worked! so simple, yet I was making it so complex...  when i copied the script that JMP wrote by way of selecting from UI, it had used the Where( ) command and not the By( )
thank you! you just saved me hours of frustration!
mpb
Super User mpb
When you interactively use a platform and specify a By variable, then instead of using Script to save the script, use Script All By-Groups from the same red triangle pull down menu. Then you'll see By instead of multiple Where blocks.
Article Labels
