Level XIII
from a name to a string
To remove a symbol, I can write:
y=6;
mySymbol = Expr(y);
//Delete Symbols("y");
////Delete Symbols(y); // <- easy
Eval(Eval Expr(Delete Symbols(Expr(Name Expr(mySymbol)))));
Show symbols()
If I need to remove a symbol from a namespace, I need the string of the symbol:
nsref = New Namespace(
	"ns"
ns:x = 20;
mySymbol = Expr( x );
//nsref << Remove("x")
Eval(
	Substitute(
			Expr(
				nsref << Remove( _sym_ )
		Expr( _sym_ ), Substitute( Expr( Char( __sym__ ) ), Expr( __sym__ ), Name Expr( mySymbol ) )
s = NameExpr( mySymbol );
str = Char(s) );  // Name not defined
Show( str );
What is the right syntax for
Char(s)
Re: from a name to a string
Head Name(expr) ?
ms = Expr(x);
Head Name(ms); // "x"
Head Name(expr) ?
ms = Expr(x);
Level XIII
many thanks, @jthi
