Mi
Mi
formula
I want to  calculate from a file the length of the successive series of each individual.
How can i calculate this in JMP Pro with the formula?
By hand i have already entered a few sequences in the Column Sequenz.
X_4 =Sequenz
Thanks.
Re: formula
All of the information about the functions and statements in the script in question can be found in the Scripting Guide available under the Help pull down menu
     Help==>JMP Documentation Library                Scripting Guide
I hope the following helps in the understanding of the formula
// The entire script will be run for each row in the
// in the data table
// On row 1 set default values
If( Row() == 1,
	value = 1;
	counter = 1;
// If the value of X__1 has changed check to see if
// more than one row has this new value of X__1
If( :X__1 != Lag( :X__1 ),
	counter = 1;
	While(
		:X__1 == :X__1[Row() + counter]
		Row() + counter == N Rows( Current Data Table() ),
		counter
	value = counter;
	// If this is not a row that has a new value of X__1
	// then set the value to a missing value
	value = .
// A JMP formula always takes the results of the last item
// processed, and makes that the value for the formula
// columns current row so by placing the variable that
// holds that value as the last item processed in the
// script, we ensure the correct value is placed into
// the data table
value;
Re: formula
Here is the formula I came up with, that seems to work.
If( Row() == 1,
	value = 1;
	counter = 1;
	counter = 1;
	While( :X__1 == :X__1[Row() + counter] | Row() + counter == N Rows( Current Data Table() ), counter++ );
	value = counter;
	value = .
value;
Mi
Mi
Re: formula
this works great!
Could you please explain to me what this means.
counter = 1; While( :X__1 == :X__1[Row() + counter] | Row() + counter == N Rows( Current Data Table() ), counter++ );
value = counter;
value = .
value;
Where can I read  or learn about it?
Thanks a lot!
Re: formula
If( Row() == 1,
	value = 1;
	counter = 1;
	counter = 1;
	While(
		counter
	value = counter;
	value = .
// the data table
value;
