BookmarkSubscribeRSS Feed
daniel_harding
Jul 2, 2012
for loop inside a new table
Hello Everyone,
I am pretty new to JMP and even newer to JSL. I am trying to get information from the user in a GUI and output all values up to their numerical choice and put that into a data table so that the user can have more information at once. This call for a loop of some sort and I've worked out the logic  for the loop. My question is this: how can I have the loop be inside of the table so that the multiple values can be shown? Below is the loop that returns what I need in the log. Thanks for any help or suggestions and just let me know if clarification is needed.
gui user input = 6;
for (totlots = 1, totlots <= 25, totlots ++,
if (totlots <= gui user input, show(totlots) );
log shows:
totlots =1;
totlots = 2;
totlots = 3;
totlots = 4;
totlots = 5;
totlots = 6;
pmroz
Jun 23, 2011
Re: for loop inside a new table
Perhaps you need something like this?
dt = current data table();
col_names = dt << get column names(string);
if (!contains(col_names, "Total Lots"),
    dt << new column("Total Lots", numeric);
lots_text = "";
nw = New Window( "Enter Lots",
    <<modal(),
    Panel Box( "Select number of total lots",
        lots_teb = text edit box(lots_text),
    Panel Box( "Actions",
        H List Box(
            Button Box( "OK",
                ok_button = 1;
                lots_text = lots_teb << get text;
            Button Box( "Cancel", ok_button = 0 ),
if (ok_button,
    lots_num = num(lots_text);
    nr = nrows(dt);
    if (nr < lots_num,
        dt << add rows(lots_num - nr);
    for (i = 1, i <= lots_num, i++,
        dt:"Total Lots"[i] = i;
daniel_harding
Jul 2, 2012
This seems to be very close to what I need. Thanks!
