chris_G_ttu
five factor design matrix in yates standared order
is it possible to make a five factor design matrix in yates stadanred order? I read on the disscusion that the run order right to left ordering is the yates standard order. I would like jmp to make a table that looks the the one below, only for 5 factors instead of 4.
Byron_JMP
Re: five factor design matrix in yates standared order
yes
Randomizing the order is better, I don't care what Yates said.
DOE/Classical Design/Full Factorial. Add 5 continuous 2 level factors, then use the sort option.
...But you wouldn't really do this experiment, right?
JMP Systems Engineer, Pharm and BioPharm Sciences
