BookmarkSubscribeRSS Feed
fit the graph background with the ms word ?
Drharsha
May 2, 2017
 i want to use this graph in excel for my work and how to fit the background color of the graph with the color of ms word ( in this case i should not have any color). I am adding a screen shot of the paper, as you can see  the background of the graph is a bit dark when compared to the background of the ms word.
David_Burnham
Jul 13, 2011
If you save the report window as an image then you get white backgrounds except for the main outline (which you could crop):
Graph Builder.pngFrom the graph window press ALT to reveal the menu.  Then File>Save As and shoose a file type such as PNG.
-Dave
Craige_Hales
Mar 21, 2013
You can also use JMP's preferences
preset.PNGOne of the presets makes white backgrounds
Craige
