extracting codes from a lot number
DKI
Feb 13, 2017
Hi
I have a series of lot number in a column and the 5 alpha numeric digits need to be extracted into one column, digits 6-8 need to be extracted to another,  digits 9-12 to another column (as per example below). I am hoping there may be a jsl code that could complete this task. I am new to jsl so any help is appreciated.
Example
Input Columns:
Lot number
H974286234825
Output Columns:
Col 1                 Col 2           Col 3
H97428             623              4825
Jun 22, 2012
Solution
Use the Substr() function,
     Help==>Scripting Index==>Character==>Substr
I have included a data table with the 3 new columns you want, using a formula for each of the new columns to get the data you want
Jun 22, 2012
Solution
DKI
Feb 13, 2017
Thanks alot Jim for the really fast response
This was exactly what I was looking for.
