BookmarkSubscribeRSS Feed
antonio-domenic
Feb 19, 2016
extract RAW datatype from Oracle database table
I have a problem when I try to extract data from a column in Oracle table that is RAW type. The result after Execute SQL() is a table with a numeric column but each cells show the dot '.' value. Of course, using Oracle SQL Developer I am able to extract the data. Is it possible to find a solution for this?
Thanks in advance
guillaumebugnon
Apr 7, 2015
Re: extract RAW datatype from Oracle database table
Are you using QueryBuilder or query into jsl.
In the second way, maybe you can try to convert RAW into NUMBER (to_number).
