hlazar
export custom color theme
My company just upgraded us to JMP13. I had a custom color theme that I want to use. Is there a way to export or transfer to the new version?
thanks
H
pmroz
Re: export custom color theme
Open up a script window in the old version of JMP and run the following program:
get preferences();
Check the log window and you'll see a long string of your preferences.  Your custom color theme will be mixed in there, something like this:
	Add Color Theme(
		{"Light Spectral", 2051, {{42, 63, 255}, {0, 170, 170}, {0, 227, 0}, {221,
		221, 0}, {238, 119, 0}, {252, 11, 11}}}
You can execute this in a JMP 13 script to load your custom color theme.
pmroz
get preferences();
	Add Color Theme(
hlazar
Excellent, thank you.
