BookmarkSubscribeRSS Feed
ron_horne
Jun 23, 2011
entering all values (rows) of a coulumn in a formula
Hi all,
need to enter all values of a column into another column formuma as in the picture below. what is the best way of doing this other than manually?
thanks!
ron
Jun 22, 2012
Solution
Re: entering all values (rows) of a coulumn in a formula
The JSL I included is a formula.  Below are images of applying this to the Big Class data table, where I have changed the name of Height to Cash, and added a column called Column 6 where I added the JSL as the formula for it.
Jun 22, 2012
I would just read them in as a list or matrix
dt = Current Data Table();
v = dt:height << get values;
// or
v = As List( dt:height << get values );
Here is a complete version
v = As List( dt:cash << get values );
TheExpr = "x=internal rate of return(0.1";
For( i = 1, i <= N Items( v ), i++,
	TheExpr = TheExpr || ", " || Char( v[i] )
TheExpr = TheExpr || ");";
Eval( Parse( TheExpr ) )
x;
ron_horne
Jun 23, 2011
Thank you Nelson, this does bring the answers neatly yet I was wondering if i could have it in the table itself so it will automatically update as i change the values in the cash column.
ron
Jun 22, 2012
Solution
ron_horne
Jun 23, 2011
Thanks again, this is perfect.
Perhaps in a future version of JMP they will introduce a standard way of entering all values of a column in to a formula. It is actually useful in many applications.
What is more striking to me in this specific example using Big Class is that the internal rate of return of an all positive series comes out as negative!!! just makes you wonder what is in the "black box"
Ron
