Françoise
empty cells, pb with zero
From yesterday, Jmp takes empty cells (with no data) for values ​​equal to zero. I do not understand what has changed. I looked in the preferences, I don't see anything.
Does anyone have a solution?
best regards
phil_kay
Re: empty cells, pb with zero
I think that it might be best to contact JMP Techinal Support (email: support@jmp.com) for this problem. Unless you can share more about the specifics of the problem here: where are the data coming from? How are you inputting the data in JMP? What are the data?
