The World Statistics Day celebration continues here in the Community. We all need reliable data for sound decision making. Do you have a data source that you trust most? Head over to Discussions to tell us about it.
fguerville
discrete time cox
Hi
Is that possible to perform a Cox Proportional Hazard Regression using discrete time with JMP Pro 12 ?
How to do it with the Fit proportionnal hazard platform ?
In my database, there is one patient per row and i know that the event occured between two visits of the study.
Thanks
Florent
jiancao
Re: discrete time cox
Discrete survival time data is not supported in the Fit Model/Proportional Hazard platform. However, you can run a logistic model after the original survival data is transformed, as shown below.
In this example, the response variable for logisitic regression will be "quit", a 0 and 1 discrete variable, where there are multiple records for those whose survival time (represented by "dur") is more than one year.  Fit logistic to discrete survival time.jpg
Please refer to 7.5.2 in https://data.princeton.edu/wws509/notes/c7s6 for details about the data transformation as well as the analogy between the logistic regression and the discrete time proportional hazards model.
jiancao
fguerville
Thank you very much, Jiancao.
In your example, how do you use the "censor" data in the logistic regression model ?
Florent.
jiancao
You’re welcome. You no longer need that since the values of the binary response variable indicate the censoring status.
