BookmarkSubscribe
zoulanlan
disconnecting the curve in fitting each value model
I'm new to JMP.9.
the problem I have is how to disconnect the x-y curve at where there is  missing data and any special point in "fit each value" model .
for example, the first pic is plotted with JMP.curve is connected at the zero point
what I want is the second pic, disconnected at zero point ( no data at x=0).
THANK YOU FOR YOUR HELP!!
