vishwasanj
Level V
data filter for loop
I am fairly new to scripting. I understand for loop but I need a little bit of help here.
I am not able to find the for loop example for a data filter in the scripting guide. If someone could help me with the syntax, that would be great.
What I am trying to do is, I have a treemap and I need to construct a 'for' loop with the data filter table to get the graph outputs saved as .png file automatically.
I have attached a figure. For example, condition 1: wafer 11, choosing all Vpp trimset for 25C and Formula NO (1 graph)
                                                               condition 2: wafer 12, choosing all Vpp trimset for for 85C (0,11111)and  and Formula NO (1 graph)
                                                               condition 3: plotting each trimset value for all for wafer 11( 9 graphs) and wafer 12 with YES (2 graphs)
I am able to do it if I do it one by one in a code, but not together.
Thank you
13 REPLIES 13
vishwasanj
Level V
Re: data filter for loop
I understand what's going on. Thank you for the really good explanation Craige.
I believe if the condition doesn't find any rows associated with the condition, it breaks and stops.
"This Where-clause for data table 'Final table' resulted in no rows: Wafer == "12" & Formula == Empty()"
Instead, can it proceed so that it can keep plotting with the loop?
David_Burnham
The example I give below contains code that will skip combinations for which there are no rows
http://www.pega-analytics.co.uk/blog/scripting-data-filters/
-Dave
Craige_Hales
Nice!
Craige
vishwasanj
Level V
Thank you @David_Burnham, @Craige_HalesCraige and @txnelson
You guys rock!
