KinKame
creating multiple bivariate chart
I would like to create thru a script multiple bivariate chart as:
tablel01 - column name list
xvar = list of column to use as X
yvar = list of column to use as Y
table02 data table
create the bivariate charts based on xvar and yvar.
I tried as follow but it doesnt work ...
//open table01
table01 = Open("C***");
xvar = Column(table01,1) << getValues;
yvar = Column(table01,2) << getValues;
tr_loop_limit = Nitems(xvar);
//select table02
current data table(table02);
Bivariate(
  for(i=1, i< tr_loop_limit +1, i++,
  Y(eval(yvar)),
  X(eval(xvar))
thank you for your support
ian_jmp
Level X
Re: creating multiple bivariate chart
NamesDefaultToHere(1);
// Make a table to use (dt)
dt = NewTable("Many Bivariate Plots",
NewColumn("Col 1",Numeric, Continuous, Formula(RandomNormal())),
NewColumn("Col 2",Numeric, Continuous, Formula(RandomNormal())),
NewColumn("Col 3",Numeric, Continuous, Formula(RandomNormal())),
NewColumn("Col 4",Numeric, Continuous, Formula(RandomNormal())),
NewColumn("Col 5",Numeric, Continuous, Formula(RandomNormal())),
AddRows(20)
// Make lists of columns in dt to use
xVars = dt << getColumnNames("String");
yVars = dt << getColumnNames("String");
// Use Fit Y By X' platform
fybx = dt << FitYByX(Y(Eval(yVars)), X(Eval(xVars)));
ian_jmp
Level X
AddRows(20)
KinKame
Ian,
good evening.
It works perfectly .... I can now go on with my little jmp scripting until next big issue blocks the road.
thank you very much for your very helpful and quick answer, makes my end of the day GREAT!!!!
best regards
Lionel
ian_jmp
Level X
I'm happy to help, Lionel, and I know that's true for the community members in general. So please do keep posting when the way ahead isn't clear . . .
