vishwasanj
Level V
creating an index for columns to point to the graph
Hi All,
I created a bunch of graphs using new window( V list box ) options in Graph builder by looping through the column names(say cols 25 to 50) which is plotted on the y axis. Is there a way to create an index on a separate window showing all the column names with a select option, after selecting it, will take/point to the specific graph?
I appreciate any input. Thanks for your time.
gzmorgan0
Re: creating an index for columns to point to the graph
Attached is an example using Semiconductor Capability.jmp.  Below it shows that selecting PNP3 in the left window scrolled down the right window
6 REPLIES 6
gzmorgan0
Do you want this action on a live current session window. Or is this some behavior for a saved journal?
vishwasanj
Level V
Hi @gzmorgan0 , live current session window. I am not trying to save anything. Maybe if I want I can always add a little copy picture with your principle later.
gzmorgan0
Look up the Scroll Window(displaybox), for a hint.
gzmorgan0
gzmorgan0
vishwasanj
Level V
Exactly what I want. That's pretty awesome. Thank you @gzmorgan0
