Batista
copy and past columns at same datatable
Hi, how can I copy and past columns at same datatable (I have 200 columns and 3050 rows) Tx
Re: copy and past columns at same datatable
It seems like you are thinking too much like JMP is an Excel spreadsheet, but given that you have sufficient memory, you should be able to cut and paste the columns into new columns
  1. Select all of the cells you want to copy, and then either
    1. Use CNTL/c
    2. Edit==>Copy
  2. Create a new column and click in the top cell in the new column and then either
    1. Use CNTL/v
    2. Edit==>Paste
    1. Use CNTL/c
    2. Edit==>Copy
    1. Use CNTL/v
    2. Edit==>Paste
