I have numeric data in the form of, e.g., 8601representing 1/1986.
I want to convert it to a JMP data value in order to be able to do arithmetic on it.
I'm using the formula below and am getting dates in the 21st century (e.g., 2086 when I want 1986).
any help on changing the formula or a workaround to get the 20th century dates I want?
The solution is pretty easy. All that has to be done is to concatenate "19" to the front of the year value you are stripping off of ODATEW
Date MDY(Num("19"||Right(Char(ODATEDW),2)),1,Num(Left(Char(ODATEDW),2))
Thank you, works great
