News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
dwmvt
control variable order in jmp 10
Simple question - how can I control the order of variables plotted or reported in output tables?  Default is always alphabetical, but often I would like to have "Before" come first, and "After" come second.  Is there a way to control this?
pmroz
Re: control variable order in jmp 10
Set the value ordering property of the column.
gail_massari
PMroz is correct. Value Ordering works in JMP 10 and JMP 11.  Display Categorical data your way, eg,. by day Mon to Sun: R. click Col>Column Properties>Value Ordering>move up/down.
