jan_kreuzmann
control chart builder: subgroup of Lot numbers in multiple charts does not stay as set when saved as script and rerun
Hello everyone,
I have the problem that I like to  use the control chart builder and the Lot numbers I put in the x-axis do not stay as set, when I save it as script to use again, once my data table is refreshed. I got four control charts save in the script and usually the first one has the set right, but the other three don't. So every time I start the script I have to set the last three control chart again. A bit of  a hassle it is.
"Charge",
<ScaleBox,
{Min( 113 ), Max( 147.5 ), Inc( 1 ), Minor Ticks( 0 )}
That's the code for the first box, but for the others it is the same:
"Charge",
<ScaleBox( 2 ),
and so on.
So where is my error? I just set all the control charts and the saved  it as a script. So I guessed JMP will provide all the right details for it.
Hope someone can help me out!
See you
Jan
Re: control chart builder: subgroup of Lot numbers in multiple charts does not stay as set when saved as script and rerun
My guess is that you are using an older version of JMP.  I ran similar code in 14.2 and saw the problem you were seeing.  I ran the same code in 15.2.1 and it worked as expected.  There was a bug that was fixed at some point.
If you could reproduce this with some example data and code that would greatly help.
Here is the code that I used that worked in 15.2.  Does this work for you?
dt=Open("$SAMPLE_DATA/Big Class.jmp");
obj=dt<<Control Chart Builder(
	Show Sigma Report( 1 ),
	Use Event Chooser( 1 ),
	Show Capability( 0 ),
	Variables( Subgroup( :age ), Y( :height, :weight ) ),
	Chart( Position( 1 ), Limits( Sigma( "Standard Deviation" ) ) ),
	Chart(
		Position( 2 ),
		Points( Statistic( "Standard Deviation" ) ),
		Dispatch(
			"age",
			ScaleBox,
			{Min( -5 ), Max( 10 ), Inc( 1 ), Minor Ticks( 0 )}
		Dispatch(
			"age",
			ScaleBox( 2 ),
8 REPLIES 8
ian_jmp
Level X
JMP is pretty good, but on rare occasions the saved script can be incomplete.Cases that are confirmed as such should be reported via [email protected]. If you are able to post your script here, I'm sure someone would take a look. Change the column names used if they are sensitive.
jan_kreuzmann
Thanks Ian for your help so here is my full script. Maybe someone finds what I am missing. See you!
Jan
	Size( 522, 452 ),
	Show Two Shewhart Charts( 0 ),
	Show Control Panel( 0 ),
	Variables(
		Subgroup( :Charge ),
		Y(
			:Name( "HCP-E [mg/L] Ernte" ),
			:Name( "HCP-E [mg/L] MF" ),
			:Name( "HCP-E [mg/L]UF/DF" ),
			:Name( "HCP-E [mg/L]Capture" )
		Phase( :Filter )
	Chart( Points( Statistic( "Individual" ) ), Limits( Sigma( "Moving Range" ) ) ),
	Local Data Filter( Close Outline( 1 ) ),
		Dispatch(
			"Charge",
			ScaleBox,
		Dispatch(
			{"Übersicht Grenzen HCP-E [mg/L] Ernte"},
			"LCL",
			NumberColBox,
			{Visibility( "Collapse" )}
		Dispatch(
			"UCL",
			NumberColBox,
		Dispatch(
			"Limits Sigma",
			StringColBox,
		Dispatch(
			"Subgroup Size",
			NumberColBox,
		Dispatch(
			"Charge",
			ScaleBox( 2 ),
		Dispatch(
			{"Übersicht Grenzen HCP-E [mg/L] MF"},
			"LCL",
			NumberColBox,
		Dispatch(
			"UCL",
			NumberColBox,
		Dispatch(
			"Limits Sigma",
			StringColBox,
		Dispatch(
			"Subgroup Size",
			NumberColBox,
		Dispatch(
			"Charge",
			ScaleBox( 3 ),
		Dispatch(
			{"Übersicht Grenzen HCP-E [mg/L]UF/DF"},
			"LCL",
			NumberColBox,
		Dispatch(
			"UCL",
			NumberColBox,
		Dispatch(
			"Limits Sigma",
			StringColBox,
		Dispatch(
			"Subgroup Size",
			NumberColBox,
		Dispatch(
			"Charge",
			ScaleBox( 4 ),
		Dispatch(
			{"Übersicht Grenzen HCP-E [mg/L]Capture"},
			"LCL",
			NumberColBox,
		Dispatch(
			"UCL",
			NumberColBox,
		Dispatch(
			"Limits Sigma",
			StringColBox,
		Dispatch(
			"Subgroup Size",
			NumberColBox,
ian_jmp
Level X
I took a look, and the 'Dispatch()' commands that modify the report seem OK. But the Control Chart Builder report is complicated, particularly with multiple 'Y' variables. Just do a right click on the topmost outline node, then 'Edit > Show Tree Structure'!
It's difficult to go further without the data, but I would recommend bringing this thread to the attention of [email protected]. Then you will be 'in the system' and are guaranteed a response . . .
jan_kreuzmann
Thank you! I am still using 15.0 as our IT department does not really get around to doing things except for looking after all the home office people. I just renewed my ticket with them and I am hoping for the best.
See you!
jan_kreuzmann
I got my update for JMP so now I am using 15.2.1, but still the control charts won't stay as I saved them, only for the first one.
So I hope someone will come up with another idea.
See you
Jan
	Chart(
		Position( 2 ),
		Dispatch(
			"age",
			ScaleBox,
		Dispatch(
			"age",
			ScaleBox( 2 ),
jan_kreuzmann
I now see it works with my scripts. Maybe JMP needed to be restarted after the up-date.
Thanks for your help!
