BookmarkSubscribeRSS Feed
djhenry
Community Trekker
Aug 25, 2011
confidence intervals in Y by X
Is there any way to save the confidence limits in the Fit Y by X platform in JMP9? I could easily show them on the graph but cannot find out how to save them to the table. If it was a linear model I guess I could use the Fit Model platform and then save from there, but in my case I fit the polynomial (quadratic equation) in the Fit Y by X platform and would like to save mean confidence intervals.
Cheers
djhenry
ms
Jun 23, 2011
If you mean the confidence limits for the fitted line (and not for the parameters) I don't think it's possible to save them from Fit Y by X.
However, you can also fit polynomials (which actually are linear models) with Fit Model. Select the variable and choose "Polynomial to Degree" from the macros dropdown menu.
djhenry
Community Trekker
Aug 25, 2011
Thanks. This is helpful.
