conditional logistic regression in jmp
I am a biologist (heavy in ecology, light is statistics).
I'm trying to determine habitat selection using a paired logistic regression, but can't seem to determine the correct settings in jmp. From my knowledge the data should be set up as the difference between the case and control, and that these will be tested against a vector of 1's (case-control). Does anyone know if this analysis is possible in jmp? Thanks.
