anneg
concatenate delete duplicates; select where - jmp list
this problem really puzzles me.
I want to make an concatenate but in the one table (dt2) I got also some entries I've got allready in the first one (dt1). I want to keep the ones in the first data Table (dt1) and want to delete them in the second one (dt2).
I allready tried and have another problem using the select where and delete the duplicates in the second table before concatenating. I have a List of all the the the duplicates, but I canot use the list as a variable in the select where clause nor the data filter
Summarize( a = by(column(dt, "band")),c=count );
The variable looks like this:
a = {"2_12_000264_0_9", "2_12_000265_0_1", "2_12_000267_0_3", "2_12_000269_1_3", "2_12_000269_2_1", "2_12_000270_1_7", "2_12_000270_2_5", "2_12_000271_0_1", "2_12_000272_1_9", "2_12_000272_2_7", "2_12_000273_1_1", "2_12_000273_2_8", "2_12_000274_0_4", "2_12_000275_1_3", "2_12_000275_2_1", "2_12_000276_1_4", "2_12_000276_2_2"};
and the complete data filter:
dt2 << Data Filter( Add Filter( columns( :Bandname ), Where( :Bandname == {"2_12_000264_0_9", "2_12_000265_0_1", "2_12_000267_0_3", "2_12_000269_1_3", "2_12_000269_2_1", "2_12_000270_1_7", "2_12_000270_2_5", "2_12_000271_0_1", "2_12_000272_1_9", "2_12_000272_2_7", "2_12_000273_1_1", "2_12_000273_2_8", "2_12_000274_0_4", "2_12_000275_1_3", "2_12_000275_2_1", "2_12_000276_1_4", "2_12_000276_2_2"}), Display( :Bandname, Size( 221, 259 ), List Display ), Mode( Show( 1 ) ) ));
But using the variable doesnt work:
Add Filter( columns( :Bandname ), Where( :Bandname == a ), Display( :Bandname, Size( 221, 259 ), List Display ), Mode( Show( 1 ) ) ));
why??
But the main problem is the above one, deleting duplicates before concatenating.
Thanks in Advance
ms
Super User (Alumni) ms
Re: concatenate delete duplicates; select where - jmp list
I don't know why, but in some cases JSL just don't resolve list variables even when a clear-text list is perfectly evaluated.
One way to get around this is to use an expression and substitute a parsed list into it before evaluation. Here's a data filter example:
dt = Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" );
a = {"KATIE", "HENRY", "ROBERT"};
df_expr = Expr(dt << data filter(add filter( columns( :name ), where( :name==a ), Display( :name, List Display ))));
Substituteinto( df_expr, Expr( a ), Parse( Char( Eval( a ) ) ) ) ;
eval(df_expr);
However, to conditionally select rows based on a list may be scripted more efficiently using For Each Row(). The result of the code below should be identical to the above (except for the Data Filter Window).
For Each Row( Row State( Row() ) = Selected State( Contains( a, :name[] ) ) )
Once the duplicate rows are selected, just run dt << delete rows before concatenating.
ms
eval(df_expr);
anneg
Thanks so much, this works great... and your first code is really good for understanding jsl
