eugene077
combining nominal columns using formula
Hello, I'm trying to aggregate data from 3 columns (coded as "nominal" yes/no) into a new nominal column using "OR" function, but keep getting an error when I put in
Alcohol abuse==1 | alcohol binging==1 | alcohol withdrawal==1
(See example below)
My goal is to have the new column report a "1" if a subject has ANY alcohol-related history, i.e. has a "1" in any of the preceding columns.
I have also tried
If(:Alcohol Abuse == 1 | :Alcohol dependence == 1 | :Alcohol withdrawal syndrome == 1, 1, 0)
but no luck - it returns all zeros...
Thank you
Alcohol abuse alcohol binging alcohol withdrawal any alcohol related problems
1 1 0 1
0 0 0 0
0 0 0 0
1 0 0 1
0 0 1 1
Re: combining nominal columns using formula
It appears that not only are your columns Nominal, but their Data Type is Character.  So for your formula to work, you either need to change the columns to be Numeric, or to reference the values you are attempting to compare using literal references.  See below:
If( :Alcohol Abuse == "1" | :Alcohol dependence == "1" | :Alcohol withdrawal syndrome == "1",
	"1",
	"0"
